The 'job' for the work party is to empty the white container to prepare for its cutting up and disposal.
It is planned to move the stuff still in the container on the 22nd onto the grass and consider it surplus to requirements and therefore candidates for disposal / scrapping / burning.
A skip will arrive around the 21st Feb to receive the foam insulation pieces as a priority and maybe the stuff that can't burn !
A replacement skip will be ordered for delivery around 28th Feb. Positioning it on the white container 'footprint' may require a further work party to be called.
Probably not a good evening to ask for assistance with the wind howling outside !
However, refreshments will be provided.....
Let people know via this board if you plan to turn up.
Regards
Roger (Project Manager - White Container Disposal)
