Merlo
Merlo
Anyone know if the merlo is working, I might come in tomorrow
Re: Merlo
Chris has told me it isn't, so it's the yellow peril then
kerrygirl
Re: Merlo
Unread post by kerrygirl »
Can anyone tell me if the Merlo is fixed or if not when it's likely to be? Thanks,Brian
Re: Merlo
Last I heard John Holt was waiting for a part. I'd email him Brian.
Re: Merlo
As of Sunday pm it was still causing concern. The mechanic is having a think...
kerrygirl
Re: Merlo
Thanks Chris and Roger. It's picked a bad time to start acting up. :roll:
Re: Merlo
The Merlo is now apparently working correctly again.
Barnfields will visit to do a diagnostic check but in the meantime please speak to Gilly before use because the issue may be down to driver error.....
Regards
Re: Merlo
driver error, like what ?
Re: Merlo
Still to be proven but it is suspected that the software requires a certain number of revs to be happy before setting off. As I mentioned, please speak to Dave before using because he's the liaison with Barnfields at the moment.
Regards
Re: Merlo
Curiouser and curiouser said Alice
slippers
Re: Merlo
Unread post by slippers »
engine speed issue we believe is sorted, back to the original problem of randomly will not select gears and over-ride has to be used,its the same problem its always had but is happening more frequently. :shock:
Re: Merlo
Thanks John and mechanics for tackling the daunting Merlo electrics, it sounds like they are getting nearer to pinpointing the problem - it is probably a tiny device on top of the injector pump which monitors the throttle position and sends a signal to the hydrostatic drive part of the ECU. If the computer doesn't get the signal it wants, it goes into "limp" mode which, on the Merlo, means no drive without switching the override switch - a viable option for an experienced driver, not not safe for a occasional user. Lets hope that the replacement will sort it. David
Re: Merlo
The Merlo is now fine. The suspect item (throttle position sensor?) was replaced with a new part.
Thanks to all who progressed the diagnosis and fix.
Regards
