Water to boat park
Water to boat park
The water to the boat park has been turned off because a bad leak has developed near Cinque Mille. If the water needs to be turned on the tap is in the kitchen near the door.
Wind Sock
Thanks for getting the new windsock Chris that looks like good value, and it even seems to be pointing in the right direction! 😏
Today I went up on the roof and changed the anemometer for a new unit so now it's working properly. Also I have put I spare unit in the computer room so next time it fails it should be a quick fix.
Re: Water to boat park
Did you know a proper windsock tells the wind speed as well as the direction
https://aviationrenewables.com/how-to-r ... -windsock/
Wind Sock
Thanks, Mick,
So it looks like ours is not far out, on Friday, before the monsoon, the new anemometer was saying 10 to 12 knt when it looked like this:
